Wheel spacers on the Kia Stinger
Dan
Fort Lauderdale
2015 Acura TLX
After seeing a few pictures of the 19" wheels on the Stinger, I think it would look much better if the wheels were more flushed on the car.
My plan is to go with 5mm all the way around. I believe Kia uses a 67.1mm bore and 5x114.3 bolt pattern. In case anyone else is interested I'm putting the link to the product down below. The 5x114, 67.1mm pattern is also shared with Mazda if you want to research your own.
Here's the link to the 5mm spacers
KiaFan
Great share Dan, thanks for the info.
67GP
Sunshine Coast
My wife's Pearl White Stinger GT
Hi Dan, please post photo's and results as this is something I'm interested in doing.
[MENTION=185]Dan[/MENTION] make sure you find/use spacers that are hub centric. That will eliminate all possible source of vibration due to miss alignment when mounting the wheels back on.
At what spacer thickness is it recommended to replace the stock studs with extended ones?
anything over 10mm will require extended studs.
However, if you are going 10mm or above I suggest you use this type of spacer
No need to worry about replacing studs, it's hub centric and it attaches to your factory studs.
Great discussion...
Let's figure-out what is the max offset that can be added without inducing ANY rubbing of the tires on wheel wheel/liner/etc.
67GP
Sunshine Coast
Hi Guys,
does anyone have a photo of the reverse side of the GT 5 spoke rims??? Also wanting to know stud length for these wheels. I'm sure I seen one on the forum but cant seem to find it. I will be ordering 20mm hub centric spacers on Monday, we just need to confirm a couple of detail.. cheers
Mt Prospect
Kia Stinger Premium
Hi Guys,
Does this help? The studs are about 14mm.
67GP
Sunshine Coast
Yes, Thank you pixeltim, I am also wanting to look at the back /inside of the actual wheel as well. I'm having the spacers made and we need to know if there are hollowed out sections in the wheel itself... regards Glen
Mt Prospect
Kia Stinger Premium
Here you go.
67GP
Sunshine Coast
Hello pixeltim, You my friend are a Champion, Thanks so much. I will get some photos as soon as I can once they are on. My girls girl is getting some personal touches at the paint shop at the moment so I couldn't get to her, I Really appreciate your help, [drinking][twothumb] Glen
Mt Prospect
Kia Stinger Premium
Glad to help.
Hey guys, I can solve all the problems for you. Eibach has Pro Spacer Kits now avaiable :)
I'm working on getting them listed on the website but if you're interested in a set (10mm, 15mm, 20mm, 25mm, 30mm) shoot us an email Sales@K8StingerStore.com for pricing!
Robs
Singapore
Singapore
Hi Paul, will the stock wheel studs be long enough to go with 20mm spacers and still have enough thread for the wheel nuts? Or would longer studs/bolts like ARP ones be safer as they are stronger?
With the 20mm spacers you will need extended studs that are INCLUDED with the kit, so there is no need to source studs from ARP
"Note: Original studs must be changed. Longer studs are included."
Forum Posts
