1/4 mile outing with the LAP3...!
Update (Vid) 1/4 mile outing with the LAP3...!
UPDATE - Stinger went to the strip again today and managed another 12.17 with the same setup as 12.16 run, took a video this time [biggrin]
https://www.instagram.com/p/Bgg7fMNAlJT/?taken-by=kiabahrain
After installing the HKS M40iL plugs (gapped at 0.024) and getting the misfire issue out of the way, I decided to take the car to the strip and test it out.
Previous best run was a 12.6, car had,
1. JUN BL Race Type Cat-Back
2. 93octane + Boostane
Today the car had the same previous setup plus the LAP3, as usual removed everything I can (spare tire, head rests etc) results below,
1. 12.58 @ 111.72mph - JUN BL Catback + 93oct & Boostane - LAP3 91oct setting (7-5-5)
2. 12.48 @ 112.34mph - JUN BL Catback + 93oct & Boostane - LAP3 93oct setting (6-6-6)
3. 12.36 @ 113.53mph - JUN BL Catback + 93oct & Boostane - LAP3 93oct setting (6-6-6) - OEM panel air filter removed
4. 12.16 @ 114.58mph - JUN BL Catback + 93oct & Boostane - LAP3 93oct setting (6-6-6) - OEM panel air filter removed - 1 hour cool down
I am happy with the results [clap]
Minneapolis
MN
Impressive, did you take any videos?
STINGER
I have a video for the 12.36 run I will post later, the 12.16 run came as a surprise and we didn't video it unfortunately.
Sacramento
Great runs. What do you mean OEM panel air filter removed? Did you remove the whole box or just the filter inside?
STINGER
Just the filter inside.
With the Boostane additive how much octane did you think you were you running?
Sacramento
It's amazing how much time you shaved off just from the filters. Wondering with the K&N filters if it would produce similar times.
SeoulStinger
Walnut Creek
2015 Audi A6
Great job [MENTION=46]STINGER[/MENTION]
STINGER
It definitely made a difference, but take the improvement with a grain of salt because the stock filters were quite dirty.
Eastern
Those are Corvette times. So close to 11 seconds. You might be the first to hit 11s.
I wonder if the rear end can handle a set of drag radials?
How was the temps when running?
Impressive times.
Make sure you run the gas tank down to the 1/4 tank too lol.
STINGER
Thread Starter #13
Temp was 24c (75f). No need for drag radials at the moment, the LC won't give 100% power until the car reaches a certain speed to avoid wheel spin, combine that with track-bite and the weight of the stinger I get zero wheel spin. I usually just spin the tires after driving over the water box to get ride of the water, but for the 12.16 run I went around the water box and immediately staged the car and didn't get any wheel spin.
STINGER
Thread Starter #14
STINGER
Thread Starter #15
#17
So these are with or without Launch Control? Sorry, confused...
Stingin' Away
Dayton
Dayton
2020 Stinger GT
They'll produce some good numbers. Get drop-ins instead of the whole kit. The factory airbox setup is maximized for air supply. My .02.
If it's for looks and a bit more noise, the kit will be for you.
Orem
UT
Congrats! Great runs!
