Kia Stinger Aftermarket Wheel Options
North Grafton
Boston
2018 Kia Stinger GT
19x8.5 or 19x9 all around would work. [MENTION=2052]LRG[/MENTION]
LRG
BARRIE
2019 Kia stinger gt line awd
North Grafton
Boston
2018 Kia Stinger GT
Awesome thanks! What do you suggest with tire size and offset ?
35mm to 40mm depending if you go with 8.5 or 9
Tire size you can go with 225/40R19
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
Overland Cayenne Diesel
You can go as wide as a 255/35/19 up front as well. We've done a few sets with Forgestar wheels since they do offer a 9" wide wheel that can be at the required offset. Also done a few with the VS Forged wheels as well. Wish I had customers submit their installed photos though... :(
Elk Grove
2018 Kia Stinger Premium
Looking at TSW Sprints 19x8 1/2 with 225/40/19 tires up front and 19x9 1/2 with 255x35/19 tires at the rear. Car is lowered with H&R springs, any issues with this setup? Thanks in advance!
MrMr
Ottawa
Lots of people have that setup, no issues whatsoever.
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
Yup, OE+ setup that we do.
Same setups on these following photos.
2001 Altezza
Do the 20's fit alright with the stock suspension? Are there any ITT? Thanks.
leecm
Franklin
TN
2019 Stinger GT2 AWD
Will 20s rub in any way if I also have eibach springs? Are there any other concerns to consider when going to 20" wheels?
The widest tire/wheel combo(stock body) is [MENTION=46]STINGER[/MENTION] and he is lowered and running 20x9 et37 and 20x10.5 et50 with 255/30s and 295/30s respectively. I don't think he has had rubbing issues but you will be fine with 20s as long as you pay attention to offsets.
Westerville
The diameter of the wheel plays a less important aspect as long as the wheel clears the strut and the caliper up front (more room for the rear). The next step is sizing the tire, depending on several aspects, the tire OD can vary as much as an inch or so from the original OD which is just about 26 inches.
The answer to the question whether a 20" wheel would fit your Stinger is it depends on the wheel and its specs.
dxccal
GRAND PRAIRIE
2018 kia stinger gt1
Fine I guess Ill post my VS Forged VS08,
Westerville
Indianapolis
IN
I agree with your assessment. I figured at that price, if the finish isn't great or doesn't hold up, I can get them refinished and still be a reasonable cost.
