Limited Slip Dif in the 2.0L?
McSlade
Cullowhee
2016 Focus RS
Does anyone know if the limited slip dif is only available in the GT? Will it be standard in the 2.0L as well? Will it be an option for the 2.0L?
KiaFan
I remember reading that both engine options share the 8 speed transmission with limited slip differential. The AWD gets torque vectoring.
Rennokas
Tallinn
Estonia
Kia Sportage 2011
I have read that the LSD will be optional on RWD versions (2.0T and 3.3TT). Not a standard feature :(
C4RN4GE
Omaha
NE
03 Turbo IS300, 16' Optima EX daily
http://www.kiastinger.org/forum/thr...both-RWD-amp-AWD-4cyl-amp-V6)?p=1487#post1487
Updated all the US spec trim levels, standard options, and packages for ya.
V6 TT is the only one that will get the LSD and it's only available in the RWD model.
*but I'm sure wait a while and people will be swapping in the LSD from the V6 to the turbo 4cyl. ;)
Allan
Foster City
I ended up buying a GT without the lsd as the dealer said it is only available in yellow in the GT trim; not available at all in the GT1 trim and standard in the GT 2 trim. I don?t like the yellow (I purchased one in white), and wasn?t willing to spend an extra 10 grand to get the lsd in GT 2 trim.
Allentown
Judging from this thread's date the information might have changed. From kia.com you can get LSD an an option on the GT regardless of color. It comes standard on the GT2. And for someone odd reason only known to Kia it's not an option on the GT1.
Allan
Foster City
Yes, it shows as an option, but when I tried to order one with the lsd, it wouldn?t let the dealer do so. Has anybody been able to order the GT with the lsd as an option (besides the yellow special edition)?
KiaFan
Maybe our forum guru [MENTION=291]MurlinatoR[/MENTION] may be able to shed some light on this.
Hey folks. Okay, so the LSD is part of the ADAS system AND AWD. So, if you choose the RWD model in GT and want the LSD, you need to add the ADAS package. It's standard on the GT2 because ADAS is also standard. They ONLY way to get the LSD in a GT1 is to take AWD.
Colors do NOT dictate the LSD, except in the even of getting the Sunset yellow in a GT with RWD because they did NOT produce any Sunset GT RWD models with ADAS.
It was my understanding that AWD did not use LSD on the rear axle. Am I wrong? Makes a difference on the rear end lube used when changing it. Wish we had access to service manuals, but it's all online these days and proprietary.
#17
Technically, that is correct. The LSD is close to the same thing that the torque vectoring system does. LSD is mechanical and the TV is electronic. They both will push the power to the tire with grip.
Forum Posts
